1 - 6 of 6 Posts
EG6
does someone have a write up on how to put the energy suspension inserts in... i just want to see how hard or easy it will be before i order them... im pretty sure my motor mounts are shot...
the vibration will be minimal. although doing mounts does mean you have to take out the engine to install the back-mount insert.(might be some other ways) imo. only worth it if you're doing a piston swap or engine overhaul and installing the inserts as a part of that process.
You do not have to remove the motor to get to the rear mount, and its worth getting rid of wheel hop instead of waiting around for an overhaul.
1 - 6 of 6 Posts
