1 - 6 of 6 Posts
I just finished putting in my new engine which is a d16y7 block with d16y8 head. Motor has jackson blower on it. There is more but I don't think it pertains to my problems. I have a vacuum leak coming from the line off the black pcv box going into the intake manifold. Also the car has no power, meaning if I even touch the gas it sputters, misfires, and will not go. I'm also getting some smoke out of the exhaust which seems to be oil. Now I saw this motor run in the car it was in before mine and had no oil issues. However my last motor I crack two piston rings and was pushing a lot of oil out before I removed it, not sure if its left over oil in the exhaust or could somehow be caused by the pcv issue. I am running a Kenji Ecu if that makes any difference. Im sure I could be more helpful but for now this is the best way I can explain it. BTW this is the first motor I have tried to use this ecu on, my other was a stock ecu. Car will not even drive up a hill. Thanks for your time and patience reading this...Any help would be greatly appreciated.
what size injectors are u using, and is the blower internally oiled, or does it receive oil from the block?
any cels?
maybe the cam is off a few teeth.
injectors are 450's I believe, the cam is not off and the motor is in time, Im using a JRSC. Don't think the injectors really matter cause I dont even have a chance to get into boost.
what injectors are they? are they dsm? did u use a resister box if they are dsm injectors or other type that are high impedance that require the use of resisters?
also is your kenji ecu setup to run the 450's? check to see if you have the map and tps sensor plugs mixed up.
1 - 6 of 6 Posts
