I'm restoring a car that's been sitting outside for 10 years, more to see here: 1st gen CRX restoration project in stopmotion video
Everything on it is JDM. Has a first gen DOHC ZC out of a 1986 Integra that has been transplanted with intake and ignition off a '89 CRX, so a bit of a mongrel.
Runs OBD0, distributorTD03u [correction - some unknown distributor from a SOHC that's bolted on with adapter withou possibility to adjust], injectors with a resistor box, MAP sensor on firewall, standalone cam sensor, ECU is PM7.
It runs, but not great. Has a slight misfire on idle and produces a lot of carbon (soot) - the rear bumper is all stained black around the exhaust. Fuel economy is actually pretty good (38 MPG), but it just runs rough and stinks (no cat - I wanna put on one, but only after I sort out the soot issue)
I already did some mechanical refresh on the engine (new bearings, hone, rings, lapped valves, all new seals, new waterpump and timign belt)
I have a brand new O2 sensor (single wire), new sparkplugs and spakplug leads. Flushed the injectors with carb cleaner both ways, cleaned the IACV, put on new air filter.
My question - what should I do to make it run well and clean? What should I buy new (considering it's been sitting very long).
I like the idea of converting to OBD1, but after soem research, I think it just isn't possible with this engine because the timing of TD43U distributor is incompatible - can anyone confirm? (as described here with no resolution DOHC ZC OBD1 Conversion - Ignition Timing - Hondata )
If someone would be so kind to also recommend parts from RockAuto I could use (I live on a remote island and it's hard to get anything here)
Also what problems can I expect? I did a lot of googling, everyone online is super confident giving advice, but then in real world the OP has some weird issue and everybody gets quiet and the thread dies. Prefer to not end up like that, so maybe stick with OBD0?
TY all!
TY all!
