1 - 20 of 61 Posts
00' Honda Civic EX
Well Im thinking of buying a ZEX dry kit off of eBay for $450 shipped. It's brand new. Anyway, how safe is that on a y8 with stock internals with some colder plugs? I'll only run the 55 shot and it'll only be every now and then. Don't plan to use it like every day or anything. How much safer does ZEX's "Active Fuel Control" feature make it then the others? I don't need to chance fucking up my motor, which is why Im only running the 55 shot. If I can find a 35 shot jet for it, I'll be using that. And how does it work? From my understanding...if you were to have it floored through every gear, it would be spraying the whole time. Or do you arm it with that little toggle switch it comes with? I've already read everything on ZEX's site. Just trying to get a little better understanding of it.
55 shot on stock plugs will be fine, just use the stock timing settings (12 BTDC) and go.
the toggle switch provides power the NMU, then nitrous will activate when at WOT.
00' Honda Civic EX
So will the n20 still spray even if the NMU doesn't have power?
00' Honda Civic EX
nvm, I figured it out. So a 55 shot is going to be safe on a stock y8? Does that little feature they have really help with safety?
No more Honda's :-(
Civic CX
all they have inside that box is a manifold just like any other dry kit uses. if you don't want the NMU to turn the nitrous on you can wire up the solenoid just like you would any other kit. my board was fried on mine so that's how i used it. it worked great. and zex uses a parker solenoid wich is a good one. i'd run atleast a one step colder plug and leave the timing stock for a 55 shot. i used the champion plugs (what ever heat range that is) and retarded the timing one degree just to be safe. the car really moved out pretty good. but if you figure how much the kit plus filling the bottle after a year costs you could be turbo and have that power all the time. i didn't think i'd care but after a couple of months of filling the bottle 3 times a month i bought a turbo kit.
00' Honda Civic EX
yea I know what you mean. I don't think I'll need to fill it that much though. I don't race to often. But I mean as long as I have colder plugs, is it safe? I have no intention of messing with the timing. And wouldn't that little box be good so that you don't end up running lean from spraying? It's supposed to prevent that by upping the fuel pressure.
00' Honda Civic EX
that's what Im wondering as well.
00' Honda Civic EX
Yea but I don't want it to kick in until around 3rd gear. Is it not bad for the motor if it's spraying through every gear? And that seems like it would really screw up the launch...
No more Honda's :-(
Civic CX
in that box is the solenoid for the nitrous, a manifold that is what ups the fuel pressure, and a circuit board thatturns the solenoid on when you go to full throttle. the manifold is not controlled in any way by electricity. no computer or anything. it's just machanical. the box is just there to make everything look nicer, it's a cover. seriously you need to check the timing and make sure it's correct. if you can set your timming you don't need to be messing with nitrous at all. that stuff can be your best friend of your worst enemy. nitrous if not properly tuned right can ruin you motor in one pass.
here's a video of my friend after running half a bottle through his motor with a zex kit not properly tuned. car ran great though. http://media.putfile.com/nickafter100shot
the nitrous only kicks in at 100% throttle. just pedal it. on the street i'd go about 80% till 5k then stab the throttle and shift right away cause of the wheel spin. let the tires keep spinning through 2nd while the car pulled hard as shit. figure a normal z6 has 125hp at the fly. add intake header exhaust and guess about 140 fhp. add a 55 shot and you've got about 200 hp. my turbo z6 only made 185 whp at 12 psi. that should be about 200 fhp. you can definatly feel the kick.
00' Honda Civic EX
Yea I understand exactly what you're saying. So just double check my timing and make sure it's all right and i should be ok? I deff won't put it on until I know for sure the timing is right. As a matter of fact, Im having it tuned, so I won't run the nitrous at all until I go have it tuned at the dyno. My tuner can ensure that it's timed right then.
This may sound dumb but how do you tell timing is set 1 degree difference I know there are only 4 marks on the crank pulley 3 timing and one tdc?
Can you actually measure degrees from the tdc mark and make new marks on the crank pulley to set you desired timing easier?
Dude you really dont know what to do with your car, first your gonna boost it, the go n/a and now your gonna spray. If I were you I would just save up and boost it and put an end to swithching back and forth!!!!
00' Honda Civic EX
I know man...I was seriously going to boost it until I realized I didn't have enough money...plus you get worse gas mileage and I don't have money to pay for that right now. I decided to spray when I read up on it more and more. Im going with spray for a while unless someone can give me a good reason not to.
00' Honda Civic EX
Exactly, I drive fast lol. I take it to 5500RPM's at least 10 times a day...
SLO SOHC said:
So if it activates at WOT would it release in 1st gear right after launching at the drag strip?
Do you wait till like 2 or 3 to actually flip the toggle switch?
if u hit the switch in first u may loose traction spin and get some wheel hop i wait till i hit 2nd then then hit the switch and floor it! to start spraying by then i have traction!!!!
00' Honda Civic EX
Discussion Starter #19
Mmk so I can wait til I have traction in 2nd before I hit the toggle switch?
1 - 20 of 61 Posts
