1 - 6 of 6 Posts
del Sol si '94
My glass wont pop up when you go to open or tilt the roof open. Unless you assist it slightly by hand, then it will pop right up and open and close properly. 95 EX Coupe.
I can hear the motor actuating and trying. Literally worked fine yesterday! lol Im going to clean and lube the tracks, but it opens and closes fine. After you pop the glass up by hand.
sounds like motor is getting weak.
You are doing it right by cleaning and lubing. Same thing that makes window motors triple their expected lifespan
Reactions: hotrodj
del Sol si '94
Fixed! Imagine that, some WD and a rag.....
del Sol si '94
Discussion Starter · #5 ·
Gonna apply a light coat of silicone grease when I get to the shop tomorrow. Been working great all day (first car with a power roof lol)
Bada bing!
use white lithium grease. (the spray kind) I put a bunch in front and behind the sliders and ran it back and forth for a bit. throw some graphite spray on the rubber gasket too to help it slide easier in and out.
Reactions: hotrodj
1 - 6 of 6 Posts
