1 - 6 of 6 Posts
Hey there!
I own a 1990 Honda Crx 1.5x with a d15b4 twin carb motor. The head could be cracked and I was thinking about swapping in a new-ish (2001-2004) d15b because it could be cheaper? +power gains.
I was wondering if there would need to be any fabrication to fit the engine into the mounts? or is the block pretty much the same as the 90's engines
'91 CRX DX, D15B (D15Z7), ZC L3
Do 7th gen engines have an engine bay mounted ECU? That could simplify or make a mess of wiring depending on how you look at and go about it. Carb'd to FI fuel supply differences?
1 - 6 of 6 Posts
