1 - 2 of 2 Posts
Well I'm doing a suspension overhaul on my 92 Civic. Replacing all bushings, shocks, etc. My concern is weather or not to be concerned about mixing and matching bushings from different companies. So far i have Pro thane front lower control arm bushings, but was planning on using In gals camber adjusting arms in the upper front, with their urethane bushings. I was also going to use their rear upper units with urethane.
I have absolutely no clue what to do with the rear trailing arm bushings, i know there has been great debate about this and I couldn't find any clear answers. Anyone want to chime in about that?
I think pro thane is the only company that makes rear compensater arm bushings, and would most likely use them in the rear lowers as well.
I will be using Tein coilovers, not sure the model, but not the most expensive or the least.
Anyone have any ideas?
You'll never find an actual answer about the RTA bushings, people will debate it to no end, but NOBODY can show proof that there a safty issue, they just say there is.
1 - 2 of 2 Posts
