What would be the "recommended" minimum clearence on both IN and EX valves?
T Threads · Registered Joined Oct 22, 2004 · 23 Posts Discussion Starter · #1 · Jan 8, 2007 Only show this user What would be the "recommended" minimum clearence on both IN and EX valves?
C Chiovnidca · Registered Joined Jun 26, 2006 · 943 Posts #2 · Jan 8, 2007 Only show this user I've always figured .060". More if you're running aluminum rods.
8 88cr-rex · D-series Janitor Front Engine Dragste Joined Oct 29, 2005 · 1,220 Posts #3 · Jan 8, 2007 Only show this user .080" on the intake, .100" on the exhaust is what I use and would probably stick with even on a honda motor.
