1 - 14 of 14 Posts
I got a promoted! And I'm PINK!!
anyone have this setup?
Mini ram turbo manifold
T3/T4 turbo
in a 88-91?
i need photos of how the oil drain is done, specifically in the 4th gen.
my turbo hang really low, i need to see how others have done it.
i cant find any pics or anything of anyone running this setup.
i am surprised.
racist-bigot-sexist-homophob
You didn't have any luck with those fittings I sent you a link of?
The manifold I have is a "mini-ram" but not constructed exactly like yours and doesn't hang as low.
clock the center section at a a slight angle and run a 45 degree fitting out of the turbo. This will create a straight shot to the oil pan.
It doesn't matter if it's in a 4th gen or not (unless you are running a stock crossmember) it will be the same in any 88-00
if i clock the turbo and use the 45* fitting its about 2 inches from eh oil pan.
insert user title here
wow, that 45* fitting is a bit long. you can pretty much but the 2 fittings together and use a very short piece of drain tube
1 - 14 of 14 Posts
