1 - 3 of 3 Posts
C
im doing a mini me swap with a z6 head on my d15b2 block. the head and mpfi swap are on the way. what else do i need? will the Z6 dizzy work for my obd0? can i use a vafc instead of a vtec ecu
B
No, as far as Ive been told, you cant.
The z6 dizzy has a different number of teeth to your standard one, so your current ECU wouldnt understand what is going on!
if you're using the obd0 setup then use a a6 distributor because a z6 distributor will not work with an obd0 setup unless you're converting to obd1. Use a 88-91 crx/civic si (pm6) ecu and yes you can use your vafc to hook up vtec. when you take out your d15 head make sure to remove the oil jet from the block. use a flat head screwdriver to pry it out but be careful of breaking it and getting it stuck in there.
1 - 3 of 3 Posts
