1 - 4 of 4 Posts
1996 Civic Hatchback
Mods- if this is the wrong forum please move this. Okay I have my y7/y8 mini me bolted together, and I just sent off my ecu (P06 chipped/socketed with crome) to phearable.net to be converted to p28 spec to run vtec. I am using an obd2a->obd1 conversion harness in my 96 model car to make it all work. My question is, what pin do I run the vtec solenoid signal wire and the oil pressure switch wires to? I found several writeups for min me swaps in older cars, but nothing specific to an ek. These swaps list pin A4 as the vtec solenoid wire and pin D6 as the pressure switch pin, but my wiring diagram says that a4 should be an injector pin and d6 is a knock sensor pin, which my motor doesnt have. Any ideas?
1 - 4 of 4 Posts
