1 - 3 of 3 Posts
C
I have a D15b2/y8 mini me and was wondering what did you guys set the timing to? It's 10.6:1 on shitty CA 91 Octane
I just got Crome pro and am going to start tuning, but want to set the timing to OE specs before I start messing with it.
Thanks!
Base timing on a Y8 is 12* BTDC. Also, you will need some kind of adjustable cam gear to get the cam timing in spec - the shorter deck height will throw the cam timing out by 4.75* or close to that.
C
I thought the deck heights were all the same? Any idea what a D15b2 deck height is?
I have a cam gear on the stock cam right now, it's at 5* retarded. I've getting a stage 1 from Crower in a week or so, just want to get everything straight before I start tuning it.
Thanks again!
1 - 3 of 3 Posts
