J
i have a a6 block with a 97 y8 head...the head has a 93 z6 camshaft and camgear...do to the stripping of the y8 cam gear bolt....so now its a y8 head with z6 cam/cam gear....i used a y8 timing belt and it was waaaaay to big...the crx si timing belt was a tiny bit too big...considering i played around with the tensioner with both belts....i hear the z6 timing belt is the same as the y8 timing belt....im stuck...which belt do i use???
if the Y8 is 106 teeth it is the same as Z6.. maybe you need a 104 teeth
98 Civic EX
D15B7 i think...............
