Hi all not posted in ages but i require some help. I am looking to mini me my civic hatch currently running a d15b2 converted to mpfi. I was just wondering what headbolts do i need to use b2 or z6 ones as im using the z6 head. And the other one is do i NEED a new timing belt tensioner or is it just advised to get one. Also i have bought the z6 timing belt that is correct right thanks guys.
Dean
Pretty sure you need Z6 head bolts.
It's always good to replace belt, tensioner and water pump when you have it apart.
i thought all engines before 96 used the same studs? 96 up use their own. thats why i had to buy a set for 95 and under and 96 andup to bolt a Z6 head on a Y7 block.
Thanks guys i have bought new bolts for the b2 i thought they would be these as they screw into the block and that isnt changing but just thought id ask thanks guys.
Dean:bong::bong:
