1 - 4 of 4 Posts
hello there
i currently have a d16y8 bone stock and everything, well 2 months ago i replaced the rod bearings and ran great till about 2 week ago when the motor decided to knock again.. well took it all apart then found out that my main bearings were shot to hell so i replaced the one's off the cradle and not the one's between the block and the crank due to fitment issues.. (i did this from under the car) well got rid of some of the knock and now im thinking the crank is damaged. so i found a cheap y7 bottom with a spun rod im going to basically rebuild this bottom end and just install my y8 head on it.. is there anything that i need to know about this swap? i heard that its a bolt in application and all i need to do is to bolt the head on etc etc.. i currently have the y8 on a ej and its converted to obd1 p28 ecu...
any input would be awesome
1 - 4 of 4 Posts
