just finish dropping a swap into a 92 si civichatch and it will not start.
OBD1
d16a6 block, d16y8 head
d16y7 dizzy
new spark plug
tranny ground, thermostat ground, vc ground
p28 ecu
prior to be dropping in, headgasket was changed, cam set at top and TDC
scenerio
put the key in, 2 clicks fuel pump prime. then try to start the car, but it wont start, but tries.
OBD1
d16y7 dizzy
new spark plug
p28 ecu
scenerio
