Its a mini me rebuilt overbored .5mm/.020in new oversized pm3s bearings rings and a z6 head stock p28 ecu. It recently started overheating so I began the process of elimination. My radiator was bad so I replaced it I also replaced the water pump and thermostat still no luck . When I took the head off I could see oil in the intake/exhaust ports. Could that be from worn valve guides/seals ? The next thing I noticed was all of my pistons except #1 had deposits on them . Yesterday before the overheating began I decided to swap in some injectors I had got since two of mine were going out. Could this be some of the cause the piston had no signs of detonation ? Any help would be greatly appreciated here is a pic not so great but you can see the piston has hardly any wear to it
