1 - 9 of 9 Posts
Been looking for awhile and can not find a definitive answer. Bought a 94 civic with a mini me swap (z6 head) and for some reason the guy put a p72 ecu on it. I plan on getting a p28 but how do I swap them? Simply plug and play since there isn't an immobilizer key for that year?
Also, I have read contradictory things about getting it chipped so I still am not sure about that either.
stock ecu will be fine. plug and play. google how to wire vtec
Thank you! BUT...
Turns out it is a p28. Car is running pretty rich. Pretty sure the o2 needs to be replaced and it looks like the cam gear is stock which I know I need an adjustable. Would that cause my car to run rich?
Also, it seems like it starts to bog down a little when driving after it warms up. Then a CEL came on and it ran a little better. Where is the plug on this thing to check codes? D15B7 with z6 head
google is faster.
make sure the timing is correct. iirc its 4.5* out
I can almost guarantee it's not correct seeing as how the cam gear is stock and therefore probably a half tooth off. But will that make it run rich? I've heard yes and no
Cel 43. So fuel supply. Guess I'll start with the fuel filter and o2 since that was my guess anyways. Thanks for the help guys
So if I go with a y8 cam gear do I just set that gear to tdc or do I still set it to one tooth difference? Which I think I advance it so 1tooth to the left?
1 - 9 of 9 Posts
