1 - 6 of 6 Posts
Z6 head, a6 block z6 headgasket with 1.181 dome and 29.5mm CH I get static compression of 10.99:1.
What will this engine be used for? Nitrous? NA?
Do forget to remove the oil restrictor on the a6 block.
It's going to be N/A, i was thinking about using some ZC piston but don't want to high of compression and not being able to get it tuned over here.
I know about the oil resrictor, thanks for the info!
NP. Thats some big bucks for 11:1 compression. Mixed and matched Oem parts can get you to 11:1 and beyond, and still be reliable. Good Luck!
1 - 6 of 6 Posts
