1 - 4 of 4 Posts
Hey Guys,
I've got a quick question.
Can i accomplish a mini-e with stock 190cc injectors and stock distributor? The rocker arms and camshaft are from a d16z6.
Thanks in advance!
(d15z8 is almost the same as d15z6)
d15z6 d15z8 is basically y8 head with vtec-e valvetrain, so yes you can swap head internals and have *real* vtech (if you were asking about this),
and yes 190cc is still enough,
iirc the intake lift/duration of d15z6 cam is close to d16z6 one,
but you'll need to tune it, 'cause vtec will not operate properly with vtec-e ecu.
on the other hand, it will start and even run )
Discussion Starter · #4 ·
Thankyou,
I've already built it that way but at some forums i read 240cc is neccesary, so that was my question, Thankyou! I will base tune it myself with chrome and later on with ectune @ a friend.
And why do some people change the whole ignition assembly??
Sorry if my english is a bit bad.
1 - 4 of 4 Posts
