1 - 3 of 3 Posts
Just finished my mine me swap . The check engine
Light code is still on for p1259 vtec malfunction . Am I supposed to reset the ecu and delete the code? Or might have i done something wrong? Before I had a d16y7 head running with a d16y8 Ecu .
same
Need more info on your new setup? What head on which block. What ecu are you running?
Are you using vtec? Hard to know without those things. Also welcome to d series.
Thanks . I put on a d16y8 head on a d16y7 block . The issue is fixed I just needed
To connect
The wires correctly from the vtec solenoid to the ecu
1 - 3 of 3 Posts
