1 - 13 of 13 Posts
Ikillyoutillyoudiefromit
07 Si Sedan
Yup. To get it perfect again you will need an adjustable cam gear. They are good for tuning anyways so it will be worth the investment.
J
so what will happen if u increase the distance via thicker head gasket to lower compression a bit in a very high compression engine?? do u retart the cam timing?
When I shaved my head 30 thousandths. I advanced my AEM cam gear 2 degrees (remember, it's only 1 "tooth" for 2 degrees)
1 - 13 of 13 Posts
