1 - 11 of 11 Posts
Hey hey.
My car has rounded 150k km (d16y7) and i want to make it run a bit better, and give it some fresh parts.
Is the AEM fuel filter worth it? Or is there any other fancy-looking or better filter i should get while i am at it? Or is OEM the shit?
I have changed oil a few times since i bought it at 142k km. It burns a bit and i have to fix that. (Bad rings or valve seals i believe.) The oil filter is good though, allmost new.
I've changed the intake and cleaned up the TB and IM. It's got a new air-filter too.
I have recently flushed coolant and changed that, and replaced a useless radiator-fan switch in the thermostat housing.
I want to change my water pump and timing belt too soon.
The spark plugs are 1k km old, so they are ok.
I want to adjust valve lash, because it's ticking abit. So that will be done.
What else should i do? Any good tips? Please include brands and such that you recommend. :)
Thanks.
I would do a compression test first and see if the rings or valve seals are bad and see general what condition the motors in. Just get a OEM fuel filter. You named a lot of good things to do. A few other thing would be;
cap
rotor
wires
injector cleaner
clean eacv or iacv
transmission fluid (Honda MTF) GM synchomesh is supposed to be s$%t.
I can't think of anything else. Maybe it's time for some mod's?
Cap? Radiator? Or...?
And what (plug)wires is recomended? Oem, or some cool aftermarket shit? :D
Forgot to mention i did a full injector cleaner/oil system cleaner/engine flush thingie a month or two ago.
Thanks.
More inputs on the topic anyone?
Yeah, new head/im/tranny maybe soon... have to see. ;) If i get those, i'm doing the whole internal clean-up i think...
B
Maybe he meant a brand used head and im, overhauled, and port matched?
J
before you get a new head etc...take existing part to machinist and have the tolerance measured if its in spec, simply buy a rebuild kit, and do rings, main bearing etc....with 150K if the engine runs good you should not need to do anymore than that....
-Juan
I think the piston rings are a bit worn. So when the new (used) head goes on i will check the rings and if needed replace them.
1 - 11 of 11 Posts
