MFactory helical LSD
Available fitments:
40mm
DOHC ZC (40mm, large axle)
35mm
-Made from 100% Pure Australian Steel, NOT cheap Chinese Steel
-Precision-machined from High-Tensile Forged Chromoly Steel for increased strength and durability
-Only the highest quality Brighton-Best Hardware is used
-Maintenance-free Gears eliminates the need for special fluids & rebuilds associated with plate-type LSDs
-Lock-free operation ensures no adverse affect to steering response
What does this mean?
NO need to tear down and reassemble correctly as you do with another brand of LSD.
NO need to replace any hardware.
NO runout problems as there are with another brand of LSD. Runout on the test LSD was .0005"!!!
No diff shim problems. Use OEM diff shims. No need for modded oil ring shims.
No problems with bearing fitment. Bearing flanges on the test LSD measured out at 40.00mm each!
No ring gear bolt clearance problems.
Weighs in at only 10.507 pounds (40mm).
D-Series.org only special, order a final drive at the same time as your LSD and receive 10% off the final drive!
Price is $699.95 shipped. Until I finish up my website and online ordering is available, please PM or email me at [email protected] to place your order. Paypal (add 3.5%), Cashiers Check, or USPS MO's only at this time, credit/debit cards may be used via Paypal if your account allows this. General questions may be asked in this thread or included in your PM/email.
Tax/duty fees not included. Tennessee residents add 9.5% tax.
Onto some pictures.
Side by side with an OBX LSD.
Another next to an OBX LSD.
Top case removed.
Completely disassembled.
Available fitments:
40mm
35mm
Onto some pictures.
Top case removed.
