1 - 10 of 10 Posts
2000 honda civic lx
Attempting to clean up this mess on my 00 sedan.. Whoever originally installed it tapped into everything which I believe is the reason left door speaker doesn't work and door locks act up..now that alarm has been removed....ideas thoughts experiences?
Have you check the door harness in the flex boot between the doors? Common problem with the 96+ Civic
92 Civic Dx
bump for good luck! i used to install them. removing these systems are never easy. Especially if it was a noob doing it because they dont tap correctly
Two men shy of a group
99 civic sedan ex
Blue/red single wire plug is for fog light power I believe. Door plug is your issue like stated, I have had to fix mine twice on two different 96-00 civics and right now my driver speaker only works with the door open
2000 honda civic lx
Discussion Starter · #7 ·
everything seemed ok. started up went to walmart went to roll window up and nothing..yet the rear windows worked..I HATE WIRING...so looks like early AM before work because its rain season in Northern Cali..also...all the plugs that were just tied up..i need to figure out where they originally went..OR reinstall an alarm system so everything works right...need to download a Chilton/Haynes..at least 1 speaker works and it runs smoothly..
Auto part Wire Electrical wiring Automotive lighting Vehicle brake
Electrical wiring Wire Electrical supply Auto part Technology
be patient. maybe 2jz will see this and stop by. I think the red/blue wire is for fog lights.
1 - 10 of 10 Posts
