1 - 7 of 7 Posts
I was just wondering what tells the ecu to spray the injectors? when I crank the engine it sprays all the injectors once then not again...then if I crank it for a while the TDC code 8 appears...yes ive swapped the dizzy with the other I had from a d16a6 both the same thing... any advice?
yes I have what would that do?? they do all spray for the initial start then dont spray after that it just cranks
i tested the TDC sensor came out fine I dont know what else to do Ive seemed to check everything...its driving me nuts...something is stopping the injectors from spraying after the initial first spray
ill go double check the resistor box...i retraced all the injector wires and plugs there in the right order...thanks..I just wanna get this damn crx running
1 - 7 of 7 Posts
