1 - 12 of 12 Posts
Was just wondering if anyone has a better idea of an amp
Speakers are:
Sony Xplod: XS-L120P5W
* 1200-watts max
* 350-watts continuous (RMS)
* 5-sided polypropylene cone for lower distortion, louder & deeper bass
* Stroke stabilizer rubber surround
* Single 4 ohm 6-layer voice coil
* Gold-plated binding posts
i have 2. now i also have the Sony XPLOD 2-channel 1000-watt amp
* Sony XPLOD with MOSFET circuitry blows the doors off the competition
* 2-channel 1000-Watt unit designed to work specifically (but not exclusively) with other XPLOD components
* Amplifier is great centerpiece in a new or upgraded car audio system
* Bridgeable dual channel amplifier
* RMS Power: 1000-Watt 4-Ohm 2-channel or 500-Watt 2-Ohm 2-channel
* Frequency Response: 5Hz-50KHz
* Signal to Noise Ratio: 100dB
* THD at Rated RMS Power: 0.04
* Low - Pass Frequency: 80Hz-80Hz
I'm not looking for a comp setup or anything just maybe a better amp for a little more power? any ideas. don't hate on the speakers it's just for me enjoyment.
Speakers are:
* 1200-watts max
isnt that backwards
do you have it all hooked up already?
Administrator
Honda
yes.. and also that could be backwards i just copied off a website =X
Holy shit, I just edited your post instead of quoting :sadface:
Sorry. Anywho my Post below.
It's backwards, and with sony's you are talking between 1/2 & 3/4ths of what they state is the RMS depending on what you get.
Crapshoot ftl :(
300zxTT, Maxima
+1, take a pass on Sony. Also, if you happen to let +/- speaker wires touch, it usually throws the amp into "protect" mode and you can't get it out. Even if you unplug the amp and pull all fuses. Usually have to send it to sony to have it reset.
i already have the sony speakers.. and i haven't had any problems. i think they sound good just maybe looking for a nice 4 channel amp so i can wire my two front speakers up in the front as well.
98 Civic EX
audiobahn sells some nice four channels for price...i'll be doing a review of in particular (a6004t) once i hook it up, but it will powering a set of infinit kappa's (2omh speakers)...
if your looking for a four channel amp check out hertz or audison. cant beat the quality. If your not lookin to spend that much money check out mtx's new jackhammer series. They are stackable so you can save space as well.
FAMILY MEMBER #316
alpine PDX series
or MRP series
1 - 12 of 12 Posts
