what is the safest the d16 can be bored out to. stock is 75mm correct? how far can you go on stock sleeves, and how far on aftermarket sleeves. and what would the final displacement be. do they sell stroker cranks for our motors.
thanks for the info my N/a buddy thats sick shit man thanks!!You can get 79mm sleeves and pistons from JGE, that makes your engine to 1765cc. That's 10% more displacement, and roughly 10% more power and torque all the way. Has potential for even more, because compression bumps up nicely and bigger bore helps valve shrouding a lot in these engines.
D17 crank (94.4mm stroke) would increase that to 1850cc.
I wouldn't bore stock sleeves bigger than 75.5mm, is you're looking for high power/rpm.
who built these?2.0L SOHC D motor has been done.......but a 1.5L was faster, go figure.
^x2.who built these?
Why don't you get lopez to regrind you a crankshaft? IIRC they are fairly reasonable cost wise and do great work (Bisi's motors???)Like a D15B crank in a D16 block????
Main bearings are the only thing stopping me.
so what would it take to run a d17 crank in a d16 block and would the hp gain be worth it?
