1 - 20 of 51 Posts
depends who you ask.....i have a 76mm stock sleeve bore with wiseco's boosted on 13psi no probs
but aalride will say like 80 mm dont listen to him unless you want a grenade for an engine!
I think you should do 81mm. I did 80mm, one month and still no problems. The only thing i´m having a problem with is oil filter blew twice, and my oil pan gasket is getting squished out. But I know what´s causing those problems. Bad PCV valve, and 2 nutz on my pump. I´ve heard of sleeper D´s with 81mm bores out in Cali, Here is a 79mm on a D
There are, reputedly, a few DD 80mm blocks out there. However, this only leaves you with 4mm between cylinders. (The bore spacing on all D-series engines is 84mm, IIRC, or 3.307".)
However, I will never personally go over 78mm. I prefer to have stronger sleeves than go for more displacement in that fashion. If you wish to have a big-bore D-series, I would recomend starting with an F-series engine and build that up. It's a SOHC, it's cheap, and it can yeild very surprising results. The only additonal expenses are a D2B swap kit and doing some fab work for a mount. If you do it right, it looks stock, but youa re starting out with a platform that will outrun just about anything D-series (B- or even K-, for that matter) for the same mods done.
whats head gasket would someone need..??? i mean 75mm to even 78mm is pretty big change, and id imagine you wouldnt be able to use the same headgasket
some of use know the thickness of the sleeves and their makeup.
At 80mm you'll be into the alum casting. behind the steel sleeves.
Max Bore
76mm stock sleeve, 78mm sleeved
Here's the response I got from Exospeed regarding max bore on a Darton sleeved motor.
"should be able to bore 79mm. but if youre on a daily driven boosted setup, i wouldnt go over 77mm bore. "
Darton's web site indicates a max bore of 78mm for their D16 MID sleeves but doesn't qualify it by application.
Cometic makes HGs up to a 79mm bore so that's what you would use. Custom size bores are also available.
1 - 20 of 51 Posts
