1 - 3 of 3 Posts
currently i upgraded my calipers, pads and rotors from my little HF setup to use the si items. im still using my HF master so the pedal doesnt have the pressure it should. will a SI master bolt up to my current booster or what? thanks guys
Shackle me NOT!!!
1995 Honda Ballade
just remember that you have to bolt on a proportioning valve when you upgrade to discs out back.........otherwise your brakes are quite a bit lower.........
1 - 3 of 3 Posts
