1 - 11 of 11 Posts
Life is taking me to a very different direction and now it time to part out my build of over 10 years. All parts are the best you can buy and most have only ever been used on the dyno. All parts are off of a d16 del Sol and work with 92-00 civic chassis. I travel for work so will be gone until 8/28. Please PM me with questions and if you'd like to put dibs on something for when I return. Email is best at [email protected].
I would like to keep the turbo kit together if possible. Here's the list:
D16 turbo kit for 92-95 civic chassis (Turbo, BOV, wastegate, IC, piping, manifold, downpipe, dumptube, oil feed line, water lines, etc.) $2000
Spoolin Performance Manifold/ Down pipe/ Dump tube ($650) -
STC Predator Turbo black ceramic coated ($650) -
Oil feed lines with Earls filter ($50) -
Tial 50mm BOV ($150) -
Tial 38mm Wastegate ($125) -
Turbo Elements backdoor Intercooler 24x8x3.5" core anodized black ($350) -
King Motorsports SS 2.5" IC piping ($150) -
Deastchwerks 800cc Injectors ($250) -
AEM Fuel rail ($60) -
King ported and modified Edlebrock Intake manifold ($500) -
Skunk2 Alpha 66mm TB ($50) -
King custom 3" Exhaust ($500) -
Eagle Rods ($225) -
ATI Super Damper ($250) -
Innovative 95a D/B Motor Mounts ($175)
Aeromotive A1000 Fuel pressure regulator ($100) -
King custom turbo grind Web Camshaft ($200) -
AEM cam gear ($50) -
ACT HD clutch/pressure plate/Street disc ($150) -
Lightened flywheel ($50) -
Hondata P28 S300v3 ($550) -
Hondata 4 bar Map sensor ($25) -
AEM Wideband ($100)
Autometer boost, water temp, oil pressure, oil temp gauges ($150 for all)
Fluidyne radiator/ Go Autoworks Fan/Shroud ($250) -
Go Autoworks Catch can/valve cover ($200)
Full race traction bars - SOLD
Endyne Ported Y8 oil pump ($100) -
Y7 bare block ($50)
Y7/Y8 Crank ($100) -
Y8 Transmission 75k miles ($150)
Go Autoworks -6AN Fuel feed lines ($50)
Full Blown 320lph E85 Fuel pump - SOLD
D16 VTEC valve cover red powder coat ($50)
Y8 Short block 65k miles - complete ($400)
Y8 head 65k miles - complete ($150)
Y8 transmission 75k mikes - complete ($150)
Y8 intake manifold ($50)
GSR intake manifold ($75)
ASR sway bar ($100)
Integra Type R OEM rear sway bar ($50)
Full Integra Type R OEM suspension ($200)
Integra GSR full set of calipers ($50)
Fidanza 7.5lbs D16 flywheel ($100)
94-01 Integra HR lowering Springs ($50)
Discussion Starter · #5 ·
Another reservation.
One more for a MOUNTAIN of parts.
Discussion Starter · #7 ·
Last reservation.
D-series SoCal Division
93' dx hatchback
Would you do a package deal?
I'm interested in:
-ITR rear sway bar
-Skunk2 66mm TB
-Hondata 4 bar MAP sensor
Discussion Starter · #10 ·
All sales will have to wait until my return on 8/28. Please send me an email if you would like me to hold anything and I can contact you upon my return.
1 - 11 of 11 Posts
