1 - 17 of 17 Posts
take a gym clip and jump theplug to check the code (the plug is under the glove box, above the kick panel on the passenge side) Jump it and it'll tell you exactly why your throwing a CEL.
pasenger side, probably has a plastic blue (or green) cover over it (If I remember correctly the plug isbrown brown...could be wrong though...blue green and brow just stick in my head) It just dangles above the ECU basically.
do nothing, hook it up(it will take care of the CEL) and jst let it hang there. ;)
ill try it. but do you think it woould hurt anything to put it in the precharge pipe?
no it wouldnt, but its hard making it seal unless you can weld plastic to metal.
i thought hondas didn't have maf sensors just map
they dont, if you read the whole thread you would have realized that he has mistaken the obd2 IAT sensor for a MAF sensor.
1 - 17 of 17 Posts
