1 - 11 of 11 Posts
Honda Civic
what the max Psi can the stock map sensor hold under boost ?
someone said i had to upgrade it. if so will a stock one out of a turbo Rx7 work.
or just buy a new one.:confused:
the stock map is good for about 11psi, any more than that up grade. a 2.5 bar is good for around 26psi
ya after around 10 is when the uprade is necessary. look into a gm 2.5-3 bar map sensor. out of an old 89 turbo sunbird if u can find one in the junk yard. or really any boosted/supercharged gm. about 80 bucks from auto stores usually. just requires a bit of wiring. or look into xenocrons stuff
http://www.xenocron.com/catalog/electronics-c-36.html
i never knew acura vigors had a 2.5 bar map. but techinically yeah....... it should work.
where did u get the information that it had a 2.5 bar map?
Honda Civic
oops my bad i was Searching the web the acura vigor 2.5L ya the map senor are the same. But what about the Acura RDX they come turbo. would that map senor work because i seen one in the yard and didn't if it intel now...
95 civic
1 - 11 of 11 Posts
