1 - 9 of 9 Posts
can anyone tell me if it is posible to use a b serie map sensor on a 89 zc civic??
ecu is giving me code 5.
and i've heard about the lumina map sensor,is it realistic????
please need help ......
btw the b serie map sensor is out of an 89 b20a lude.
1dosent HAVE to be, if you have a z6 manifold, its mounded on teh TB, just extend the connector wire to reach.
2honda uses a stock 1.7bar map in all civics/integras last time i checked
1) i was refering to 100% stock cars, so yes or no? i am under the impression of yes.
2) i already knew that part. i was going to put it up in my first post, but decided it was common knowledge and did not include it.
quick way to answer it, try it. if it plugs in and runs, then yes it works, if not, then no
heh
1 - 9 of 9 Posts
