1 - 13 of 13 Posts
93 & 94 civic sedans
So, I have a "daily torture" medium-ish compression N/A d15-a6 EG car. Trans is finally picking up some input shaft noise. I have another manual trans in unknown condition, and I am up for a re-build because of this. My question is, what are your thoughts on p20 v.s. s20? What gear ratios would you suggest for an interesting build? Tall 5th would be nice. Where could I locate some nice kits? I will be more than happy to post the build once I gather the info and parts. Thanks in advance!
bone has posted everywhere gear ratios he likes, thinks would be fun, or what other people ask for. based on just reading bone, I had him build me a y7 trans with a 3.7 (I THINK) fd and a quaife lsd. just do a little reading around for bone's posts and see what the guru says
http://www.knology.net/jediklc/gearratiosdseries.htm
close ratio ZC tranny, 48 mpg so far. Will drop in Si 5th, making it basically a DX when in 5th gear.
4.25/.702
or 3.889/.771
Thanks for the directions! The table is interesting. I am just now starting to gather info on these. There is so much to go through, floating around.
Honda Tranny Gear Ratios
That link is FUCKED UP....the idiot misquoted so many things I fucking gave up on him.
1996 Civic Type DX
EX trans, MFactory 4.9 FD, MFactory helical LSD. If you do a lot of stop and go add in an MFactory 3.083 1st gear. Plan on a full master rebuild kit with carbon-lined synchros. All parts can be ordered from me and I'd be happy to take care of the build for you.
Thanks Aquafina, but I am going to tackle this one myself. I will keep you in mind about parts.... I basically, just wanted to hear opinions and recommendations of those who care to share. Anything in particular to look for that might be abnormal compared to similar transmissions? Problem areas of special attention? Thanks for the input transzex.
Sweet, How "streetable" are these LSD's? Sometimes, those lane suggestion lines get slick, HA!
Daily driving a Quaife that was installed over 10 years ago, expect MFactory to last just as long or longer.
1 - 13 of 13 Posts
