1 - 20 of 74 Posts
\/ apply baby lotion here \/
'98 Civic 4 Door
Here we go,
I used 600 grit sandpaper to sand down the surface a bit
(400 grit sandpaper would do also)
after using a few sheets if sandpaper, here it is ready for paint..
VHT Ceramic spray paint is what I used for this.
(This paint is teh sh!t)
'98 Civic 4 Door
Now, after a couple hours out letting it Dry, I washed my greasy/oily hands to handle Header and install carefully. I chose to cure paint installed...
Here She is
Important curing on Car instructions (Read Spray can),
I let motor idle for 10 min. and turned off for 10 min.
Then let motor again idle for 10 min. and turned off for 20 min.
Then I went to go grab something to eat and came right back home.
That should do it. Looks waaaay better!
looks good...reminds me that i have to do mine....
Ive always had the stuff peel off, and chip. But I didnt do the on car drying instructions. I cured mine in the oven. Id like to see if this actually stays or not.
'98 Civic 4 Door
Prep'd it good?
can has instructions on curing in oven or on vehicle.
I ain't sticking no parts in the oven. Wife would throw a fit :pinch:
I'll keep thread updated as time goes by.
I also have a cool title
Prep'd it good?
LOL so would my wife...Looks good
Prep'd it good?
It was just scuffed with 400 grit. But it was brand new parts, cast manifold, turbine housing, and freshly welded dumptube. I used to do paint prep in a body shop, so I have some experience as well. I would say it was prepped well enough, it seemed to adhere great.
I probably didnt have it on the car for at least a week, after painting and baking, and within 2 days it bubbled and chipped off.
Hopefully you have a better experience, but even friends that did this on none turbo applications had poor results as well. :(
[EDIT] I recently used the rest of that can of paint on my new dumptube and downpipe, right before I wrapped them in header wrap. I should go pull that off ( not reusing the pipes anyways), and see what it looks like. If I remember, I will tomorrow.
FF Misfit
Accord
That looks really good. I'm glad you're making good use of the header.
formerly allnaturalrex
1989 honda crx si
had to repaint mine after i had the o2 bung welded on the correct side now just need to wrap it.
ministry of mayhem!
93 honda integra
looks good, pata!
Asshole
I thought I had pics but no. I had a 2 piece DC header that someone else painted with high heat paint and it turned a really bad ass bronze color the first time I started my car. I'm going to see if I can get it to happen again on my 1 piece DC.
1 - 20 of 74 Posts
