1 - 14 of 14 Posts
Is there some alternative to a mainshaft holder to crack the countershaft nut? i have been to every tool shop and auto shop around and no body has a main shaft holder is there some other way to hold the shafts still to un-do the nut?
d-series smartass
i was wondering the same thing. they are usually tight as crap, and i don't know how i would have gotten mine loose if it wasn't pulled out and on an engine stand. the impact wouldn't do it, but a prybar on the flywheel bolts and a breaker bar did.
im trying to peice a hybrid box together so both donor boxes are sitting on my garage floor i was thinking of wrapping some cardboard over the splines and then clamping it into a bench vise or something
S
get some wood blocks and place/clamp them around the counter shaft in the vice then you'll be able to get the nut off woth a breaker bar, you have to use a soft wood so you dont mees up the teeth on the gears. trust me it will work, thats how i did mine, and it worked wonders.
transzex said:
one leather glove and 1/2" impact gun.........30mm nut
are you meaning hold the pear with the glove or the mainshaft? im not to sure about mincing my fingers in the gears this is the first time ive stripped a gearbox so please forgive my ignorance.
but without undoing the countershaft nut to take my 5th gear off how do i seperate the case from the flywheel housing?
well, what chevy tranny your working on??????
You never told use which one your working on :):)
I'll guess a CG tranny????
Ask gtpilot, those are his specialites.
lol no no this is a jdm dohc zc tranny , sorry if im being a pain but ive never done tranny work before. The haynes manual says to remove 5th gear and asociated synchro and selectore fork and then slide the trans case off the shafts so that they are left sitting in the flywheel housing.
throw that POS Haynes in the fucking garbage!!!!!!!!!
It is giving you directions for a 84-87 Civ/Teg tranny.......
Remove shift interlock bolt (8mm hex/allen head) in clutch housing side (always tight as a mofo, use a impact!)
Remove the countershaft lock ring access plug.....3/8" square drive.....DO NOT use a impact when reinstalling it!!!!!
http://www.bettendorf.com/~mrbone/pictures/Tranny-General/oops.jpg
remove reverse switch, then all the bolts holding the case on, 17? I never counted. Open the countershaft lock ring....the countershaft might drop......you'll need these
http://www.bettendorf.com/~mrbone/pictures/Tranny-General/cm-45492-3.jpg
Now the fun part, prying the cases apart. 92+ have prying points, 88-91 don't! So you have to find the spots that allow a hammer and punch to assist in breaking the seal. Do not pry on the seal surfaces!!!!
Once cases are 1/8" apart open the countershaft lock ring as it usuallys reseats......countershaft should drop.......once the ring is clear of the bearing pull the outer housing off.........
Simple eh?
Now, why are you opening the case to begin with?
thank you for that , its difficult using an american manual for a jdm car. Im pulling it apart because i want to peice together a hybrid box using the doch zc l3 and a zxi integra l3 , im going to put the 3rd and 4th from the zc into the integra box hopefully my kaaz lsd from the zc box will fit in the integra case becasue i want the 4.2 final drive
1 - 14 of 14 Posts
