Most likely rebuilding my Z6 and was wondering if I should go back with OEM bearings or if anyone has other preferences in brand? I am about to rebuild a B16A as well, so this information will help me decide what I should put into the B as well. Thanks in advance!
oem
91 CRX Si
OEM, mic'd and color matched would be ideal for longevity. However, I used Federal std and had no issues. I plan on running ACL race next time around.
oem color matched if you can affors to spen like 200 for bearings if not i used kings and liked them alot acl are also very good but are normaly on backorder from fj
Yea, I priced some OEM's from the local dealership. $150. So I'm going with them. Off topic, but wanted to make sure a P28 ECU will work with a D15B. I've read and people confirm the maps work fine with the D15. Getting a chipped ECU for my Z6 and want to make sure everything works fine before I buy it.
