1 - 6 of 6 Posts
98 ex coupe
Honda Part Numbers - B16a, B16b, B18c/Type R
Note: The first 2 characters of the 3rd column of the part number signifies spec. level:
A0 = USDM spec.
00 = JDM goodness!
P73 = Integra Type R
PCT = Civic Type R
P72 = B18c
PR3/PW0/P30 = B16a
BLOCK INTERNALS
13010-P73-A00 STANDARD BORE PISTON
13011-PR3-004 STANDARD BORE RINGSET
13020-P73-A00 .25MM OVERSIZED PISTON
13021-PR3-004 .25MM OVERSIZED RINGSET
1310-P30-G00 STANDARD BORE PISTON
13020-P30-G00 .25MM OVERSIZED PISTON
13021-PR3-003 .25MM OVERSIZED PISTON
13310-P73-J01 CRANKSHAFT ASSEMBLY
13810-P73-J01 CRANKSHAFT DAMPENER
90017-PR3-003 CRANK DAMPENER BOLT
90704-634-000 CRANK KEY
13210-P73-000 CONNECTING ROD ASSY
1332_-PR3-004 UPPER MAIN BEARING
1334_-PR3-004 LOWER MAINBEARING
1321_-P72-003 CONN ROD BEARING
CYLINDER BLOCK
11000-P72-811 BARE BLOCK ASSEMBLY
91214-P2F-A01 REAR MAIN SEAL
11200-P72-010 OIL PAN
11251-P30-004 OIL PAN GASKET
11221-P72-000 WINDAGE TRAY
15650-P30-000 DIP STICK
11950-P73-J00 ENGINE BLOCK STIFFENER
CYLINDER HEAD
12100-P73-J00 CYLINDER HEAD ASSEMBLY
15810-P30-005 VTEC SOLENOID
12251-P30-014 HEADGASKET(VTEC)
90006-P72-003 HEAD BOLT
12204-PR3-305 INTAKE VALVE GUIDE
12205-PR3-305 EXHAUST VALVE GUIDE
12237-P30-000 CAM RAIL
HEAD COMPONENTS
14711-P73-J01 INTAKE VALVE
14721-PR3-000 EXHAUST VALVE
14761-P73-J02 OUTER IN.VALVE SPRING
14751-P73-J02 INNER IN.VALVE SPRING
14761-P72-003 OUTER EX.VALVE SPRING
14751-P72-003 INNER EX.VALVE SPRING
12210-PZ1-003 INTAKE VALVE STEM SEAL
12211-PZ1-003 EXHAUST VALVE STEM SEAL
14765-P30-000 SPRING RETAINER
14781-PR7-A01 SPRING KEEPER
14620-P30-000 ROCKER ARM ASSEMBLY
14631-PR3-000 ROCKER ARM SHAFT
14820-P73-J01 LOST MOTION ASSEMBLY
THROTTLE BODY
16075-P07-000 MAP SENSOR O RING
16176-P73-004 THROTTLE BODY GASKET
16400-P73-A01 THROTTLE BODY ASSEMBLY
16411-P73-000 THROTTLE CABLE BRACKET
36450-P6-S01 IDLE AIR CONTROL VALVE
36455-PT3-A01 IACV O RING
VALVE COVER
12310-P73-A00 VALVE COVER
12341-PR3-000 VALVE COVER GASKET
12342-PG6-000 SPARK PLUG GROMMET
90442-P73-J00 CHROME GROMMET
90213-PH3-000 CHROME 10MM NUT
12500-PR3-000 IGNITION WIRE COVER
15610-P2E-A01 OIL FILLER CAP
ENGINE HARNESS
30530-PV1-A01 KNOCK SENSOR
31112-P2T-000 LOWER ALT. BRACKET
31113-P2T-000 UPPER ALT. BRACKET
37240-PT0-014 OIL PRESSURE SWITCH
78410-ST7-003 SPEED SENSOR
32110-P73-A02 ENGINE WIRING HARNESS
32610-ST7-961 ENGINE GROUND WIRE
DISTRIBUTOR
06302-PM6-H00 IGNITOR KIT (non-OBD distributor)
CLUTCH PACK
22300-P73-025 PRESSURE PLATE
22200-P73-R01 FRICTION DISC
22100-P73-005 FLYWHEEL
91006-634-008 PILOT BEARING
90034-689-000 CLUTCH BOLT
90011-PH3-000 FLYWHEEL BOLT
EXHAUST MANIFOLD
11942-P73-000 EXHAUST MANIFOLD BRACKET
18100-P73-A00 EXHAUST MANIFOLD
18100-P73-J12 98 Spec. ITR JDM 4-1
18199-P73-J01 JDM 4-1 2.5" O RING
???-P73-??? JDM 4-1 BRACKET
18120-P73-J12 JDM 4-1 TOP HEAT SHIELD
18121-P73-J12 JDM 4-1 BOTTOM HEAT SHIELD
18115-P30-013 EXHAUST MANIFOLD GASKET
18229-SP0-J51 EXHAUST MANIFOLD DONUT GASKET
18120-P73-A00 OUTER HEAT SHIELD
INTAKE MANIFOLD
06164-P2J-000 FUEL INJECTOR
16472-P0H-A01 INJECTOR SEAL RING
16473-P10-A01 LOWER SEAL RING
91301-PM7-003 INJECTOR O RING
16620-P72-010 FUEL RAIL
16622-P73-000 FUEL RAIL STIFFENER
16740-P73-003 FUEL PRESSURE REGULATOR
16010-SK7-506 FUEL FILTER (DA Integra)
17100-P73-A00 INTAKE MANIFOLD
17100-PCT-000 INTAKE MANIFOLD (CTR)
17105-P73-A01 INTAKE MANIFOLD GASKET
17132-P73-000 INTAKE MANIFOLD BRACKET
17130-PM6-003 PCV VALVE
OIL PUMP
15100-P72-A01 OIL PUMP
91308-PK1-003 OIL PUMP O-RING
91212-PR4-A01 OIL PUMP FRONT SEAL
15400-PR3-014 OIL FILTER
15232-PG6-000 RELIEF VALVE SPRING
15231-PE0-000 RELIEF VALVE
15220-P72-000 OIL STRAINER
15221-PW0-S01 OIL STRAINER GASKET
37500-P72-A01 TDC SENSOR
18121-P73-A00 INNER HEAT SHIELD
OIL COOLER
15500-PR3-013 - OIL COOLER
15560-PT6-003 - BOLT
19505-PR3-000 - WATER CONNECTING PIPE
19423-PR3-000 - OIL COOLER LINE (OUT)
19422-PR3-000 - OIL COOLER LINE (IN)
11108-PR3-010 - NIPPLE
WATER PUMP
19200-P72-013 WATER PUMP ASSEMBLY
19222-PR4-003 WATER PUMP GASKET
19505-PR3-000 WATER CONNECTING PIPE
91314-PH7-003 WATER PIPE O RING
19320-P30-J00 THERMO HOUSING INNER
19311-P2T-000 THERMO HOUSING OUTER
19301-P08-316 THERMOSTAT
37760-P00-004 THERMOSWITCH
37870-PJ7-003 COOLANT TEMP SENSOR
37750-PH2-014 TEMP SENDING UNIT
19315-P30-J01 UPPER HOSE OUTLET
TIMING BELT
14111-P73-J00 98 INTAKE CAMSHAFT
14111-P73-J01 01 INTAKE CAMSHAFT
14111-PCT-000 CTR INTAKE CAMSHAFT
14121-P73-J00 98 EXHAUST CAMSHAFT
90741-657-000 CAM KEY
91213-PR3-013 CAM GEAR OIL SEAL
12513-P30-000 CAM SEAL BUNG
90031-PV0-003 CAM GEAR BOLT
14211-PR3-003 CAM GEAR
14510-P30-003 T-BELT TENSIONER
90026-PR3-003 TENSIONER BOLT
0214400-PR3-004 TIMING BELT
14400-P72-014 TIMING BELT
00231110-P01-003 ALTERNATOR BELT
11840-P72-010 BACK UPPER TIMING COVER
11820-P72-000 FRONT UPPER TIMING COVER
11810-P72-A00 LOWER TIMING BELT COVER
part numbers courtesy of lyonels garage at "http://lyonel.orconhosting.net.nz/honda_parts.htm"
found this site while building my b18 and it was wicked helpful. hope others can get the same use out of it. :honda:4L!
1 - 6 of 6 Posts
