1 - 7 of 7 Posts
Hello,
Do M factory not do a 35mm option for their plated diffs? I can only find helical diffs as their 35mm option.
I don't mind going 40mm but it makes it a bit of a paint having to find and buy the correct drive shafts.
LEe
Axles don't matter unless you are running DOHC ZC diff.
Kaaz made their plated LSD to run 35mm or 40mm with the use of sleeves, dunno if still made.
I've evidently got confused somewhere down the line. I always thought it reffered to driveshafts for some reason.
Am I gunna have to pull my box to find out the bearing size? It's an l3 SI casing or the UK equivalent.
USDM STD Civic and HF CRX's had tiny 23 spline outer drives, everything else was 26 spline. Inner drives were the same.
HF axles, even the hollow tube long axle has survived 200 whp pulls.
1996 Civic Type DX
Pop an axle seal out and post the pic and I'll let you know which LSD you need to order from me.
1 - 7 of 7 Posts
