1 - 6 of 6 Posts
Fo Do' DX daily
1996 d16y7 166k miles
starts up and idles high about 1500-2000 once its warm up idle stays consistently low
id say prolly 500 rpm
sometimes it will idle around 1k (on the tach) and i feel like thats where it should always be but it always goes down, its consistent but low
ive adjusted the idle screw before but it always seems to either get too high or too low so i put it back to the stock markings
any help would be great
also car seems to be getting no-so-well gas mileage and exhaust smells a little rich
thanks in advance
ministry of mayhem!
93 honda integra
probably you're rich. did you checked the spark plugs?
ministry of mayhem!
93 honda integra
does the idle goes down almost to the point of shutting off the engine and goes back?
or maybe its not so dramatic, but it goes searching up and down?
do you have a fpr? at which psi do you have it set?
you've changed spark plugs recently. did you checked them today?
if they're soot black, your engine is rich.
ministry of mayhem!
93 honda integra
also, does it sputters if you give it gas at a stoplight?
1 - 6 of 6 Posts
