1 - 16 of 16 Posts
97 Expedition
Hey guys, I'm hoping someone could shed some light on an issue I've been having. A while back I put in a SOHC Vtec zc obd1 engine in my 95 dx. It ran great for several months and only acted up once with a bad coil that I replaced. Well about two weeks after the coil I was driving home and noticed that it was a little lacking in power but I was tired so I didnt check on it til the next day. I had a ton of new parts I intended on putting on so I started with what I had: Fuel pressure regulator, fuel pump, fuel filter, igniter, plugs and wires, map sensor, swapped tps with another but ran the same, checked the mechanical timing, did a compression test which it amazed me with 195 in every cylinder, checked the ohms on the injectors, and I swapped to a po6 ecu just to see if it would change anything and it didnt... wth am I missing? anyone? PLEASE? lol
you replaced the coil and igniter? there are other non-replacable sensors inside that can go bad.
I would swap in a known good distributor and swap your new coil and igniter (ICM) in there.
97 Expedition
You mean those magnetic pickup cps? I did an ohm test on all three and they are also within spec. can they be bad and still read right? I've tried finding a working distributor but could only find a d15b7 one. I've changed all of the internals of d series distributors before, I wonder if the b7 cps would fit into the vtec one...
97 Expedition
well the internals on the non vtec dizzy seem to be identical so I swapped over the magnetic sensors and started the car.. it runs SLIGHTLY better but still a misfire at all rpms under load. trying to find a known good working dizzy to swap over just to see if it helps as the b7 dizzy i pulled parts from was unknown if working or not.. could the IAT sensor cause bad running if its bad? any way to test it if so? I have no CELs and the light does work
you swapped the sensors? Might have put them lined up incorrectly.
I would try to find an old d16z6 distributor, and swap it in place. by gut swapping, it merely means wiring, ICM, and coil. gerenlly the housing sensors (cylinder, crank, top dead) shouldnt be touched. Seems they are lined up a certain way.
How are your plugs looking? I would yank one out, regardless of how new it is, and see if gap changed, or if its showing signs of burning super lean or whatever
97 Expedition
I did pull the plugs yesterday and they were kind of a dusty red color but very light. all of them looked the same.. yes you might be right about those sensors, there are three that look the same and i guess it could be possible I swapped one of them into the wrong place or something. I am hoping to borrow one from my buddys running car for a min to see if it makes a difference today after work. thanks!
97 Expedition
Well... I went to my friends house who has a z6 hatch. swapped dizzys and it ran the same.... seriously feel like Im running out of options as Ive tried almost everything i can imagine besides swapping injectors in case clogged and checking all of the wiring
outside of listening to each injector with a stethescope, I would recheck mechanical and ignition timing
97 Expedition
two of theninjector screens got gunked up. prob solved... note to self.. start with the free stuff before throwing money at it
Most of the time injectors get clogged, there is a hole in the fuel filter underhood or a tear in the fuel sock off the pump in the tank.
I would repalce both AFTER running a bunch fo fuel system cleaner.
My normal recommendation is a bottle of Chemtool B12 at 1/2 tank and run dry, but for you I qould run it with a little less gas to stengthen the mix. After you run the tank dry, THEN replace those parts.
Did you run system cleaner previously? Because if those injectors were that bad, you are about to fill up the udnerhood filter fairly quick again.
at least a fuel filter is under $10 shipped online nowadays!
97 Expedition
I run fuel system cleaner at least once a month.. I think my prob is that I ran it almost out of gas and when i filled up it had already sucked a bunch of crap in there. next time its low Im going to drain it and see if its so bad I need to replace it. This car is getting newer..lol. New engine n trans, n pretty much every sensor and fuel system part is new.. i sure hope running this tank doesnt gunk things up too bad
pop the rear seats back off, yank the fuel pump assembly, remove the sock, reinstall pump assembly, and use a spare hose to pump the shit out. Could have a guy underneath feeed the new hose between the tank and chassis so you dont risk getting fuel everywhere inside.
Once its empty, hose the shit down with some brake cleaner, or fill the tank with mineral spiritsa and give the car a few good shakes.
Drain it again, and you should be good.
Once the majority of the garbage is gone you should be fine. Then you can reinstall the pump sock.
1 - 16 of 16 Posts
