1 - 9 of 9 Posts
1995 del sol d15b7-d16dz6 mini me swap.
Engine starts and idles fine. When it has run for about a minute idle starts loping and is fine after car gets to operating temp. Throws a trouble 1 at this point. Have replace o2 and iat sensors but same issue.
bleed the coolant system
How did you bleed it? I normally just start the car, let it warm up and circulate the coolant, while adding coolant as needed. Until it stays the same. Then I just top it off. There is often a bleeder on the top coolant inlet where it meets the block. You can use that also.
1 - 9 of 9 Posts
