1 - 20 of 25 Posts
Honda Civic?
So, swapped the z6 into my EK, re-welded my exhaust from the EG myself and I took out the 3” flex section in the downpipe itself and I put in a 2.5” --> 3.0” adapter so I could clear the AC compressor this time around.
I drove it about 50 miles, over 3 days after the first start (in the new car):
8 of the 9 cylinder head exhaust bolts were loose and one was gone – used lock nuts (stock)
2 of the 4 bolts of the 4-bolt T3 flange were gone and 1 was loose, 1 was fine – I Used Flat washers & lock washers (Grade 12.9 M10x1.50 metric bolts)
4 of 5 downpipe bolts were loose, 1 was fine. I used no lock washers (Grade 12.9 M8x1.25 bolts)
2 questions:
1.) For those of you that have had this type of problem, what did you do to fix it? I don’t think loctite can handle the heat (even the 242). I guess I need better lock washers? What can I do here? Maybe thread tape?
2.) Are my exhaust bolts becoming loose because I don't have a flex pipe anymore? I don’t remember having this issue before…
You need the flex section for a reason. Your other option would probably be solid motor mounts. The movement of your motor, with the leverage of 8 feet of exhaust translates a lot of movement in the back, even if its only 1/4" at the motor.
If your exhaust bolts stop coming lose, youll probably crack the exhaust in half.
1992 Civic Si
Those nordlocks are sick. If the stover nuts on my setup ever back off, I'm switching to those.
Honda Civic?
thanks for all the links/info guys, i guess you live and learn... it was my first time putting an exhaust in a car, i realize now that the flex section absorbs all the transversely mounted engine vibrations..
i will put that flex section in tonight, I'm glad the turbo didn't fall off on the freeway... :TU:
Honda Civic?
question, where should the flex section be placed in the downpipe? the 3-bolt connection to the rest of my exhaust is about where the firewall/steering rack is or just a tad more towards the rear of the car.
Would it be alright to install it as far back as where the axles are-ish?
Thanks!
EJ1-Taffeta White
I put mine right after the pan under the axle.. But that's where I ran outta pipe to from building the DP, but I know that's roughly where I've seen other companies put them.. I would deffinately put it before the firewall/steering stuff.. Too me that's less that the motor and manifold and all would have to move before the flex, so less weight to move and to me, less stress on turbo, manifold, etc.. Lots of room there too..
See above...
Yep, you need a flex section to help you out there. Right after the oil pan is a good place. My setup consisted of a 3" DP with a flex section, OEM exhaust header nuts, and grade 8 nuts/bolts/lock-washers/washers from Lowes. Never had one back out on me.
Put the flex wherever you have the most clearance, and as early as possible. Consider that if the motor is the pivoting point, a 1" movement at the motor, can translate to a foot (just an example, not factual number) at the rear of your exhaust.
So you want to put the flex as close to the motor as possible. You definitely want the flex, prior to where you exhaust is mounted to the car.
The other option is to run open downpipe. No flex needed. :)
I think theyre your standard 14mm bolt. I got mine from the hardware store when I had one. Cant remember the thread pitch, m10x1.5?
ej8
If that's for me I got bolts but I want to switch to studs and nuts.
Dont mean to thread jack. But whats the best choice for the hardware to attach the turbo to the manifold. Nuts and bolts or studs and nuts?
90 CRX
Definitely using studs is the way to go. Find nuts that have a shoulder made on them and also have the jagged edge on the clamping side. O Rielly's is your friend. If you have a bolt take it with you to the parts store.
1 - 20 of 25 Posts
