1 - 14 of 14 Posts
I've been looking at manifolds and I'm thinking a log manifold. I priced one at $250 vs a cast one for $100. What do you guys prefer to use?
Cast..... from everything I read when I was debating between the two, it holds up to stress a lot better, and its kinda like a mini ramhorn, and there cheap but also ugly.. the logs look god but I hear they crack easier
I'm using an ebay cast one here. Works fine, one hole was off by a hair but I drilled my turbo exhaust housing just a little bigger to fit.
Mine was $50 shipped from a member here, can't beat that price vs a log
From my personal experience, cast.
My friend's civic made 300+whp for many many many miles on a really ugly looking $75 cast manifold, it cracked a couple times but he welded them.
The thing was great though for the price.
Cast doesnt look as good but last longer. Id go cast cheaper in price and will hold up better.
wasnt that me lol. You finish you kit yet? I just need management and ill finally be done.
Mazworx $160ish Shipped
RCAutoworks $160ish Shipped
Mazworx has a way better Head flange then RC, but RC has a way better turbo inlet flange lol. RC looks to be out of stock for his diy kit, but sells them welded already for $300.
Or just this simple GReddy style knock off for under $100 shipped
Only problem is my turbo has a Chrysler T3 flange, not a normal T3
Yessir! Around mid-December I made 300whp/265ftlbs for 2 days and then turbo took a dump. Waiting on it to get back from mhamrick, it'll have a T4 44trim compressor instead of the T3 one.
I haven't had much issues with my wastegate placement on the #4 runner, but that's not to say you won't. It held 20psi on the dyno just fine. I'm running an open dump under the motor.
The yea that manifold will work but it also puts the turbo closer to the block then the other ebay castiron if used to keep ac.
Thats cool, sucks about the turbo taking a dump on you.
No A/C or power steering
1 - 14 of 14 Posts
