1 - 17 of 17 Posts
1971 VW Super Beetle
I can feel a lip at the top of the cylinder where the rings probably do not reach on the z6 block I just bought. I am curious as to if I should have it machined down to match the rest of the cylinder or if it will not hurt anything.
the cylinder probably has a lip its called a ridge, how many miles are on it, and what are the specs on the bores are they in service limit are the straight and still round
the lip indicates where the bore has worn itself into an egg shape.
you should over bore to fix it properly.
if u are throwing in some pistons that have a lower ring position, you could technically run it like that since the ring wont ever reach the ridge.
if u installed a piston with a thinner ring land, and the ring was higher, then you could have some serious problems without an over bore.
ej1
^^Well put. That's were the top ring ends. Most end up looking like that with mileage.
The mileage on the motor is unknown. It isn't carbon build up. My fingernail will catch the ridge.
I was planning on cleaning and reusing the pistons in it. It sucks that I have to have it bored and have to buy new pistons. There goes my affordable rebuild :/
ej1
If you're using the same pistons they won't be going above that ridge hypothetically speaking. Plenty of people just rehone and go, with good results after a hard brake in.
ej1
I used my shop formans version of one on a d block but his was a little jacked up and didn't work very well.
Yeah already figured that one out last night while I was at auto zone. I'll start calling up machine shops to see what kind of prices there are to have the block machined. What should I be expecting? Also because I am sending the block out what else should I might as well have done?
honda/firebird form.
bored, honed, resurfaced if needed and then cleaned... make sure you give them the girdle also so they can clean it with the block
same
that motor must have a ton of miles on it. i've torn apart quite a few z6 and never had more than a tiny ridge, could be rust build up on the ridge making it look ALOT worse though.
i'd hone a cylinder yourself and see how it looks.
1 - 17 of 17 Posts
