1 - 2 of 2 Posts
I have a 99 civic wont go over 4k rpm I swapped a d16z6 motor into it but had to use the y8 injectors from the y8 I am heading to my work to get my scanner to look for codes. Someone suggested that the injectors r wrong and someone else says it's the computer cause it's a different motor any advice is much appreciated to figure this out.
z6 doesn't have crank position sensor or knock sensor so that might be your problem
1 - 2 of 2 Posts
