1 - 3 of 3 Posts
K
I have a code 4 &1 and I repaired wiring on the crank back to ecu and no more 3500rpm redline but now I have code 8 & 1 and tried crossing the tdc wires and it wont start but the only code flashing is 1 long blink with 6 sec pause and it repeats itself. If I cross the back..starts right back up. HELP!
Hmmm, by repairing the wiring, I'm guessing you ran new wire from the crank angle sensor to the ECU right? You've disconnect the negative terminal and cleared the codes too right?
Clear the codes, if your still throwing 1 and 8 test the o2 sensor and the TDC. If the TDC is bad your going to have to replace the distributor (distributorking.com :) )
Everything is at TDC right?
1 - 3 of 3 Posts
