1 - 7 of 7 Posts
ive noticed that none of the lights in my cluster like the engine, abs, etc....dont come on what can be wrong??
DROP IT LIKE IT'S HOT
2003 Civic Si
Maybe a bad cluster or blown bulbs. I had a bad cluster i changed it and everything started to work again
how long have you had the car? is this recent or always been like this?
Check your fuses....
but I don't think the check lights share a common fuse.
However, if it is a blown fuse, you need to find out why your blowing a fuse or else it'll keep coming back.
Otherwise, it sounds like a harness problem...
Maybe a wire or the harness has scrubbed through and has grounded out?
Do the gauge illumination bulbs work when you turn on you park/headlights?
-ic
M
the same has happened to me while wiring my swap
what fuse do i look for?
what else could it be?
when i put my e-brake the light doesnt come on and at times when i turn on the car and i got the e-brake on, the light comes on and goes away in 3sec w/out takin the brake off.
1 - 7 of 7 Posts
