1 - 20 of 38 Posts
So dudes I know we all sit around and dream about what we would build if there was no budget limitations, so I thought I would make a thread that we could all dream in and share. Only requirement is that its a D-series motor build. From a NA mini-me monster build to a super-charged turbo zc, lets hear it...
Or delete me if I am a retard. :hammer:
Budget Build:
mini me my sohc non-vtec zc, drop in a very aggressive cam, light flywheel, I/H/E, do a mpfi swap....... and call it a wrap... Im not some punk kid that wants to street race, so that should be enough to add a lil bit of pep without adding more maintenance.
The rest of my money will go towards suspension.
I'd keep my JRSC once I get it tuned up on Hondata and ditch the FMU/FER, and eventually go to an 8psi pulley.
My no-budget aspiration would be to convert my DD into RWD. :mrgreen: I know it's been done, but I have no idea how much $$$ that conversion would cost.
PM
racist-bigot-sexist-homophob
d-series Member
rwd with the d series would be different, id do it too. engine bored, sleeved, built, id shoot for 500+whp however it took to get there. full suspension. strip and fiberglass the interior, carbon fiber hood n hatch and roof cap for looks and maybe some weight savings, the rest of the exterior would be stock. rwd hatch would be so beautiful...
Wait, no budget and it only has to be a D-series? Hmmm....
I'd go with a High Comp, D16Y8 with streetable ITBs, hopefully around 450HP...
...In a Lotus Elise...
No Tune No Life!
1992 EG Coupe+Endless Pile of parts=Hopefull something fast soon
D16a6
Vitara Pistons
Eagle Rods
KMS Block Gaurd
ARP head studs, Pressure plate and flywheel bots
D16a6 head race port
delta 282 grind
iskey valve springs
supertech valves
RC 650 injectors
BDL Fuel rail
Walbro 255 LPH High pressure
Pression Turbo 5130e turbo(about a 57 trim t3/t4)
ex tranny obx lsd
ACT Xtreme Pressure plate and street disc
Crome Pro
Innovate SSI-4 and XD-1 Wideband
ES full chassie bushing kit
AGX Shocks
Skunk2 Drag spring kit
the build should be done soon the best part about it is the chassis was FREE!!
D16a6
Vitara Pistons
Eagle Rods
KMS Block Gaurd
delta 282 grind
iskey valve springs
supertech valves
RC 650 injectors
BDL Fuel rail
ex tranny obx lsd
Crome Pro
AGX Shocks
I like this build!
1 - 20 of 38 Posts
